red914 |
...i believe in coyotes and time as an abstract... ![]() ![]() ![]() Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 ![]() |
well, i have some ideas, but they are not good. it looks like it is coming out of the dipstick tube, or around the breather box (?) under the oil filler neck. it is not leaking a huge amount, just getting the top of the engine wet, with some oil pooling on the engine tin.
i have replaced the gasket between the engine and the breather box thing. that seemed to do it, but only for short drives. today went about 20 miles, and fresh oil was on top of the engine. it seems to be coming out laterally, and not really spraying all over; just flows around after it is down. any ideas? thanks ahead of time. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
That blob of grey stuff is most likely JBweld. A previous fix. That hole in the tin should have been bigger with a grommet imo. Unvented heads can cause enough back pressure to overwhelm that gasket.
Britt, if I see duct tape on your car, I'm gonna hunt you down and make a mummy outta you with that same roll of tape! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
