i have an oil leak..., and i don't know from where! |
red914 |
Apr 3 2005, 11:00 PM
...i believe in coyotes and time as an abstract... Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 |
well, i have some ideas, but they are not good. it looks like it is coming out of the dipstick tube, or around the breather box (?) under the oil filler neck. it is not leaking a huge amount, just getting the top of the engine wet, with some oil pooling on the engine tin.
i have replaced the gasket between the engine and the breather box thing. that seemed to do it, but only for short drives. today went about 20 miles, and fresh oil was on top of the engine. it seems to be coming out laterally, and not really spraying all over; just flows around after it is down. any ideas? thanks ahead of time. |
red914 |
Apr 5 2005, 09:00 AM
the 34s have just a throat. not really a stack. your synchromter fit perfectly around the outside of it. inside there is a squarish thing which prevents an inner seal. all the synchrometers i have been ready to buy only have the rubber cone, not the sleeve/cuff thing on the outside of the synchrometer body.
off to look at oil leaks. thanks, as always, Kevin. |
