Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
it basically extends the length of the threaded portion on the tie rod end?
femal thread that screws into the tie rod end, and then a threaded portion for the struts pitmann arm? seems way too simple....for 200 bucks.. |
Aaron Cox |
i do understand the 'it holds my life in its hand' concern....
raising spindles is too much work (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) all it is is turned metal and a heim joint.... not hard. if you use a cotter pin... you wont die.... the heim idea is cool... no play whatsoever... even if you used just a heimjoint and a LONG bolt and a metal spacer tube... how is that effective? just thinking out loud.... safety first... (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 11:56 PM |
