Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
it basically extends the length of the threaded portion on the tie rod end?
femal thread that screws into the tie rod end, and then a threaded portion for the struts pitmann arm? seems way too simple....for 200 bucks.. |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
If the piece were made from one piece of some very strong steel alloy it wouldn't have broken. Perhaps Astralloy or some 4340 you probably wouldn't have any problems. It would need to be case hardened. They probably use a grade 8 bolt. Grade 8s can be to brittle. Grade 5s will bend before they break. WE also don't know what kind of maintenance the owner did either.
Lo-Fi Version | Time is now: 29th June 2024 - 12:08 AM |
