Working on my 914 all day on Thursday.., got a "bunch" of stuff to do.... |
Mueller |
Apr 6 2005, 09:33 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
in order of importance...more or less:
remove Mallory distributor and install stock 1.7 dizzy with FI trigger points clean and test all connections to the engine wiring harness remove the relay board and inspect/repair/clean as needed install modified MPS that is tweaked for current 1.8 motor install brand new batter cables find or make a new batter hold down clamp bleed calipers make the VW Bug tow bar pictured below work on my 914 remove rear shocks/springs, modify the perch to lower the car at least 3/4" or more in the rear since is riding too darn high depending on how time goes: install front and rear needle bearings make the RX-7 caliper adapters and mount the billet hubs with big brakes I'm sure I'll find more items that have to be taken care of so car is road worthy so that'll mean bumping certain to do items off the list...... Attached image(s) |
Demick |
Apr 7 2005, 08:52 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Mike
Sounds like you won't be using that towbar. But for those who might be considering making one - get the super beetle tow bar rather than the standard one (standard one is pictured in Mike's post above). You can see that the standard towbar is made to clamp onto some large diameter tubing which would be heavy/awkward to replicate - or you have to make major modifications to the towbar itself. The super beetle one should be much easier because you shouldn't have to modify the towbar at all - just make the proper bracket that it attaches to. Super beetle towbar pictured below: (IMG:http://www2.cip1.com/photos/ACC-C10-1402-2.jpg) |
Lo-Fi Version | Time is now: 6th January 2025 - 06:17 PM |
