red914 |
...i believe in coyotes and time as an abstract... ![]() ![]() ![]() Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 ![]() |
well, i have some ideas, but they are not good. it looks like it is coming out of the dipstick tube, or around the breather box (?) under the oil filler neck. it is not leaking a huge amount, just getting the top of the engine wet, with some oil pooling on the engine tin.
i have replaced the gasket between the engine and the breather box thing. that seemed to do it, but only for short drives. today went about 20 miles, and fresh oil was on top of the engine. it seems to be coming out laterally, and not really spraying all over; just flows around after it is down. any ideas? thanks ahead of time. |
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
Shane,
The three-way you're taking about is a viable source of leaking. Two of the hoses come from the heads. The thrid hose, on top, goes to the air cleaner. Because its a tight fit there, I've opted for a spring clip type of clamp. They seem to on reasonably easy with a plyers. I also use the fabric-coated vacuum hose for these rather than the straight rubber hose. Enjoy - and stay dry! |
