jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
I need some help with the wiring of my new combo gauge from Palo Alto:
The old gauge had a red light for generator, red light for low fuel, oil temp light and oil pressure light green and brake warning light red. The new combo gauge has green, red and blue. What from the old gauge is supposed to go into what on the new gauge? The combo gauges each have 3 connections. ground (ground symbol), positive 12 volts (+ symbol) and the gauge sensor (G), right? Comparing old to new: for example, in the factory manual (914-6) and for my old gauge, the oil temperature sensor, #11, went to the gauge. There was a connection #10 called "terminal #15" that went to both the oil gauge and the fuel gauge (I think). Is that the 12 volts for the gauge? Ground was provided through the casing? For the old oil pressure light, there is a green/red wire on the outside connection and 2 red/white on the inside connection. the red/white wire seems to go to all the bulb connections. Is the green/red the old sensor and the red/white 12 volt power, or what? I didn't label wire #12, fuel sensor well. Is it a green wire do you know? Finally, according to the manual, going across the back of the old gauge from right to left on the horizontal diameter, there was: #9, oil pressure light #8, brake warning light #0, not used #5, generator light but, in fact, according to my notes, #0 was used. there is a black wire on the outside and the red/white on the inside connector. Do you know what this was/is? |
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
the red with white wire is a key on power wire, it goes to the oil pressure light, tach power, fuel gauge, brake waring light, and oil temp or pressure gauge if you have them.
the turn signal, high beam, and gen light come from other places. these get power from other places |
Lo-Fi Version | Time is now: 26th June 2024 - 02:05 PM |
