ok, so I got a little of the bad stuff, rust, that is... |
tat2dphreak |
Mar 16 2005, 07:24 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
it's not much, and it's mostly surface rust on the long, the jack post brace is worse... but the long is solid...
I'm thinking: grind/brush off all the rust and then ospho(or metal ready) and por-15 is that good enough for solid metal? or should I put a plate over it after that as an extra brace? let me know what you think... btw, when I took the rocker off, no less than a pound of DIRT fell out!! I know to clean this spot, but evidently the last guy forgot (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s) |
rhcb914 |
Apr 13 2005, 09:20 AM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
I am just about done with the same repair. You could probably just cut off the posts and support and weld on new ones. I got my parts from Tweeks $20 for both the post and support. Not sure about the front area of the rocker. Mine were solid so I didn't mess with them. You could probably just bend some sheet metal. I fabricated all of the patches using the side of my work bench and a BFH. They came out pretty close to the original. Not concourse quality but pretty nice.
Check out my progress thread. Maybe it will give you some ideas. Good luck!! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) Jack Post Repair |
Lo-Fi Version | Time is now: 26th June 2024 - 07:06 AM |
