Engine turns and fires, then revs then dies, ?Rule out catastrophic engine failure |
echocanyons |
Apr 17 2005, 04:54 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Sorted through the fuel pump issues that I was having with the boards help.
Went through the vacuum hoses for the FI system and it all appears to be correct. car is a stock 72 1.7 D-jet NOW: The car turn over fires then revs high to 3000 for a couple of seconds then dies. I remember this happening to my 74 right after it needed a top end rebuild for failure of which I cant recall How should I go about checking to see if the engine has had a failure Compression test? anthing else? Other open ended possibilities that run through my mind are MPS problems, incorrect fuel pressure cuz I still havent been able to find a guage/tester that I can run with inline with this setup. |
Joe Bob |
Apr 17 2005, 05:11 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Pressure or filter....
Lo-Fi Version | Time is now: 26th June 2024 - 03:45 AM |
