> The Billet 4 bolt hubs worked GREAT!!!, Thanks Mueller !!
john rogers
post Apr 18 2005, 09:14 AM
Thanks Mike, the test this weekend was a huge success and I was amazed at how much difference the vented rotors made as I had no fade like I experienced last year. I got back from CT Thursday at noon and put the bearings in the hubs and the studs in. The only issue I has were the grease seals kept wanting to pop out so I staked the inner lip where they press in and they stayed fine. The SC rotors fit exact as did the loaded calipers I bought. I used the pads that came with them and will get some race pads in the next week or so. The rear brakes stayed the BMWs with no prop valve. I used a 36 piece of flex brake line on each side in the front to get a little more heat disapation. The brakes worked amazing in the practice sessions and the race and I found I could go further into a corner that even the Mitsu-Evo or the Subaru all wheel drive cars. Under full load braking the car was straight and no hint of any tale wagging at all, maybe due to the larger pistons in the M calipers as opposed to the BMWs? After the practice race I checked the bearing play and noted the cross hatching was not even worn any on the rotors!
Thanks a million and I would say the test was a huge success as far as I am concerned. I will post some assy and race pictures later today or tonight.
john rogers
post Apr 18 2005, 10:36 AM
Thanks Mike, the specs as follows: All steel body with glass, fiberglass flares with 15x7 rims and Goodyear 9x23x15 slicks (9.5 in wide). 2.0L six (184HP at rear wheels on a dyno) with oil tank, batt and trans pump/cooler in rear trunk. 12 Gal fuel cell forward of the bulkhead and huge front oil cooler. Only one seat with 6 pt roll cage, cool suit, video system, etc in the middle of the car. Trans has K-Q-V top gear set and GT limited slip so top speed is about 130 to 135 MPH and I shift with one of James' Rennshifts (great). It weighs 2300 # with me in the car so I guess I need to go on a diet??!! The car is about as low as I can get it as in Tacate I was sending sparks from the floor pan on some of the bumps, need some of those rub strips the rally cars use. I have 23mm T-bars in front, 300# springs rear Koni sport shocks, large front sway bar, stock rear sway bar hooked up. I use one of the Merc 23mm M/C and so far have had good luck with it. Oh yea, it is now purple with bright orange numbers!!!!
john rogers   The Billet 4 bolt hubs worked GREAT!!!   Apr 18 2005, 09:14 AM
Mueller   glad to hear this John !!! can you pl...   Apr 18 2005, 09:17 AM
Root_Werks   The mythicall hubs on a car!?! http://www.914world.com/bbs2/h...   Apr 18 2005, 09:41 AM
LouisCypher   And me 2 pairs in 4-lug htt...   Apr 18 2005, 09:58 AM
john rogers   Thanks Mike, the specs as follows: All steel body ...   Apr 18 2005, 10:36 AM
Brad Roberts   Thanks John. Sorry it took so long to get the hubs...   Apr 18 2005, 02:07 PM
LouisCypher   Hi Brad, are the hubs with studs or can they be u...   Apr 18 2005, 02:39 PM
Korijo   what if someone wants them, but wont be attending?...   Apr 18 2005, 02:49 PM
john rogers   Thanks a zillion Brad. They were most definateky w...   Apr 18 2005, 02:56 PM
Brad Roberts   Louis, They are designed for use with the stock l...   Apr 18 2005, 03:04 PM
Brad Roberts   Hi Dave, http://www.914world....   Apr 18 2005, 03:07 PM
Brad Roberts   Here is what they look like on the Ecomm site. I n...   Apr 18 2005, 03:11 PM
Brad Roberts     Apr 18 2005, 03:15 PM
Korijo
  Apr 18 2005, 05:59 PM
Brad Roberts   Thanks James http://www....   Apr 18 2005, 06:01 PM
Qarl   Why wait for the WCCC? Just order the hubs online...   Apr 18 2005, 06:16 PM
Brad Roberts   Quarl hasnt been hacking into it lately... the pri...   Apr 18 2005, 06:52 PM
Qarl   It still says $1.00   Apr 18 2005, 08:21 PM
Qarl   Is that one of AA's restorable 914 tubs on the...   Apr 18 2005, 08:23 PM
Qarl   Cool! I tried to order the $405 billet h...   Apr 18 2005, 08:40 PM
LouisCypher   Hi, how do I get into the shop? Regards, Louis   Apr 19 2005, 01:50 AM
McMark   It's not actually "open for business" yet. Ap...   Apr 19 2005, 01:56 AM
LouisCypher     May 3 2005, 12:13 PM
tat2dphreak   why would you think you could buy if the store isn...   May 3 2005, 12:22 PM
Brad Roberts   Do to my travels to LA today.. (I'll return We...   May 3 2005, 12:33 PM
john rogers   Don't dispar, they are well worth the wait...   May 3 2005, 12:39 PM
LouisCypher
  May 3 2005, 02:13 PM
Dr. Roger   PLEEEEZ talk to me. I love hearing about new prot...   May 3 2005, 03:14 PM
SirAndy     May 3 2005, 04:35 PM
Aaron Cox   lost something in translation... As one calls int...   May 3 2005, 04:38 PM
Gint   Hey B&A! nannernannernanner!!!...   May 3 2005, 05:23 PM
SirAndy   <...   May 5 2005, 07:11 PM
Bleyseng   How are the 5 bolt hubs coming?? I am just sitting...   May 5 2005, 07:17 PM
Mueller   <...   May 5 2005, 07:23 PM
Mueller   Hey John....anymore track events running the new b...   Jun 3 2005, 02:29 PM
SirAndy   oh. yeah ... maybe i should have made that more c...   Jun 3 2005, 11:09 PM
kdfoust   I'm dragging this thread out of the dungeon an...   Jan 27 2007, 02:51 PM
McMark   They are, contact Mueller for the latest info.   Jan 27 2007, 04:33 PM
neo914-6   They are, contact Mueller for the latest info. ...   Jan 27 2007, 05:15 PM
john rogers   In case anyone wants to see the hubs in action, th...   Jan 27 2007, 04:42 PM
Mueller   Kevin, send me your contact info and i'll get ...   Jan 27 2007, 07:05 PM
kdfoust   Kevin, send me your contact info and i'll get...   Jan 27 2007, 07:35 PM
mikez   That's nice....sure wish he/Brad would take ca...   Jan 27 2007, 07:07 PM
swood   *hijack* Hey Kevin, did you ever get my response/...   Jan 27 2007, 09:18 PM
kdfoust   *hijack* Hey Kevin, did you ever get my response...   Jan 28 2007, 10:46 AM
hcdmueller   I am interested in a set also. Is there any chanc...   Jan 28 2007, 07:10 AM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th June 2024 - 10:05 AM
