Filling Up The Roll Bar, ...with expansion foam... |
McMark |
Jun 24 2003, 10:31 PM
I've read a bit about sound deadening and one technique is to fill hollow spaces with expanding foam to kill resonance. I was thinking of doing this to my roll bar top and maybe the sides. Knocking on the top shows how high of resonance it has. I was think that if I drilled some hols 8-10 inches apart on the underside of the roll bar and sprayed in the foam I could kill the resonance and just fill in the holes. I'm not sure I could weld them since the foam is in there, but maybe solder or lead them in, or maybe just bondo?
What's your reaction to this? Good or bad idea? |
Jeroen |
Jun 25 2003, 05:31 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
You are kidding right?
Look what the factory installed foam already caused us (rust wise) and now you are planning to add to that? And no, after you've inserted the foam, you can no longer weld (the foam will burn and melt) Finally, I think you will achieve very little from this. Face it, a teener is a noisy car cheers, Jeroen |
Lo-Fi Version | Time is now: 24th June 2024 - 11:34 PM |
