McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I've read a bit about sound deadening and one technique is to fill hollow spaces with expanding foam to kill resonance. I was thinking of doing this to my roll bar top and maybe the sides. Knocking on the top shows how high of resonance it has. I was think that if I drilled some hols 8-10 inches apart on the underside of the roll bar and sprayed in the foam I could kill the resonance and just fill in the holes. I'm not sure I could weld them since the foam is in there, but maybe solder or lead them in, or maybe just bondo?
What's your reaction to this? Good or bad idea? |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
Also, please keep in mind that IF you do use foam to fill up these cavities, that this foam expands.
If you apply it wrongfully, the force of the foam-expansion may warp and disfigure the surrounding sheetmetal. So, if you decide to go the foam-route, be very carefull! cheers, Jeroen |
Lo-Fi Version | Time is now: 25th June 2024 - 12:02 AM |
