McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I've read a bit about sound deadening and one technique is to fill hollow spaces with expanding foam to kill resonance. I was thinking of doing this to my roll bar top and maybe the sides. Knocking on the top shows how high of resonance it has. I was think that if I drilled some hols 8-10 inches apart on the underside of the roll bar and sprayed in the foam I could kill the resonance and just fill in the holes. I'm not sure I could weld them since the foam is in there, but maybe solder or lead them in, or maybe just bondo?
What's your reaction to this? Good or bad idea? |
914Timo |
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe ![]() |
Jeroen is right about the expansion and I have to say here that it may not be very wise to use any spray-foam or other 1 component foam. The volume of the targa bar is so big and there are too few and too small holes to outside, that it will take a long time until the foam is cured. I think you should use 2 component foam that cured chemically, not by air-drieing.
Lo-Fi Version | Time is now: 24th June 2024 - 11:25 PM |
