Ignition 101 needed badly., Any professors out there? |
Porsche Rescue |
Jun 25 2003, 04:11 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Ok-got my fresh 19 year-old engine turning over just fine (did you know that the starter speeds up a lot if you connect the tranny ground strap?). Got fuel squirting in all 4 throats. Got juice at terminal 15 of the coil with ignition on. Won't fire at all. Took dist. cap off, turned on ignition and opened and closed points with tip of a screwdriver. No spark at all. Condensor lead is attached to #1 coil terminal and to points. Help Please! I REALLY want the hear it run (and maybe even go for a drive). Distributor, points, condensor, rotor and cap are new Bosch 050 direct from the box.
Lo-Fi Version | Time is now: 28th September 2024 - 02:57 PM |
