Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I did a brake inspection, changed out the rear springs, pulled the distributor for a part # and am replacing one of the oil lines above the chain cover.
What year and car is this dizzy from? I'm going to order a Pertronix module. KT Attached image(s) ![]() |
Trekkor |
I used the sight hole between the engine and trans. on top of the motor.
I was listening last year when somebody said "mark the flywheel". I marked TDC with a yellow "T", 120* and 240* for valve adjusts with yellow lines and 30* timing mark with a red line. KT |
Lo-Fi Version | Time is now: 25th June 2024 - 08:13 PM |
