ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
I fear my right rear suspention ear has been ovaled due to rubbing of the trailing arm shaft and the ear. With the rear jacked up I can move the wheel back and forth. Not much, but I see the trailing arm moving at the ear. I want to catch this before it gets more serious. How much would it cost to fix the ear hole? Is this something I can do in my garage, or should I let the pro's do it? I "might" have access to a welder, but I dont have access to experience.... :toilet:
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,985 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
QUOTE(cha914 @ Feb 2 2003, 11:49 AM) Chris, I don't know anything about derlin...what is special about it itself...and what is so unique about your installation? Thanks for the help, Tony Delrin is a hard (usually black) plastic, much better suited for suspension bushing material than Teflon, Nylon, Poyurethane, etc. It is of a higher quality than the polygraphite bushing material and it will last longer. The polygraphite is molded, while the Delrin must be turned on a lathe. I prepare the trailing arm by reaming the hole accurately, so my bushings press in with the right pressure and they are aligned to one another. That way the shaft, which I have ground slightly to provide a fresh smooth surface, fits without binding. I also add grease zerks to the trailing arm to lubricate the bushings, and trim the end of the bushings to fit the shaft precisely. I have seen some variation in length of the shaft, as well as the trailing arm, so there is no "one size fits all" solution. |
Lo-Fi Version | Time is now: 30th April 2025 - 03:46 AM |
