> Pushrod tube seal replacement, You guys help me out
bd1308
post Apr 24 2005, 02:50 PM
Sir Post-a-lot
I pay over $600 at the "Porsche" place to get them replaced...perfect. I take them to the VW guy to get them replaced, $20 labor and parts and nada....i know the guy is cheap, this is why "I"want to do them myself. Somebody PLEASE tell me how to clean the ports up (where the seals go) cause the VW guy says that's what is needed and he can't do them real well.
ThinAir
post Apr 25 2005, 04:22 PM
Best friends
QUOTE (bd1308 @ Apr 25 2005, 03:12 PM)
paint from the tin..? what paint are you referring to?
I'm referring to body paint in the engine compartment. Castrol Super-Clean is said by many to be something that you do not want to use on painted surfaces because it will harm the paint. I've used it successfully on the paint in the engine compartment as well as the underside of the trunk (above the transmission) and because I did not leave it on too long before rinsing it did not harm the paint at all.
I've found the paint on engine parts tends to be pretty tough so that you don't need to worry about it like you would about body paint. I've also used Super-Clean on engine tin that I was intending to repaint as part of an overhaul and I found it to be one of the best cleaners around for prepping the tin for painting. The Super-Clean helped me get the tin ready for painting, but was not the cause of needing to paint the tin.
bd1308   Pushrod tube seal replacement   Apr 24 2005, 02:50 PM
914rrr   Elbow grease, patience, scotchbrite pads and some ...   Apr 24 2005, 03:16 PM
bd1308   carb cleaner was suggested.....so i've persona...   Apr 24 2005, 03:19 PM
scotty b   You've had this car for 3 months and have spen...   Apr 24 2005, 03:30 PM
bd1308   okay okay i was fecetious....i've had this car...   Apr 24 2005, 03:33 PM
scotty b     Apr 24 2005, 03:37 PM
bd1308   so every person has smokescreen syndrome when they...   Apr 24 2005, 04:00 PM
Lawrence   That smokescreen is from oil leaking onto the heat...   Apr 24 2005, 05:20 PM
redshift   Take your heaterboxes off, and spackle the crappy ...   Apr 24 2005, 06:30 PM
bd1308   speaking of heaterboxes, i was trying to install m...   Apr 24 2005, 11:32 PM
dmenche914   To answer your question. You need to clean the...   Apr 25 2005, 03:48 AM
groot   Excellent explanation! Thanks! I need to ...   Apr 25 2005, 08:27 AM
Mueller     Apr 25 2005, 11:22 AM
bd1308   okay it was $160 for everything....including ...   Apr 25 2005, 11:28 AM
dmenche914   Do not know if they can be replaced while motor is...   Apr 25 2005, 11:30 AM
Mueller   Dave, I am 100% positive you do not have to drop t...   Apr 25 2005, 11:34 AM
groot   Cool. I've got a gasket set on order and I...   Apr 25 2005, 11:43 AM
bd1308   back to the subject....i kinda wanted to keep the ...   Apr 25 2005, 11:50 AM
Mueller     Apr 25 2005, 11:57 AM
Aaron Cox   http://www.914world.com/bbs2/h...   Apr 25 2005, 12:12 PM
bd1308   he replaced them, but told me they will prolly go ...   Apr 25 2005, 12:13 PM
Mueller     Apr 25 2005, 12:30 PM
dmenche914   if mike says it can be done with motor in car, the...   Apr 25 2005, 03:41 PM
ThinAir914   Mike is right that you can do this with the engine...   Apr 25 2005, 03:59 PM
bd1308   the only thing that scares me is jack-stands....bu...   Apr 25 2005, 04:04 PM
bd1308   i have valve cover gaskets.....i'll do that ne...   Apr 25 2005, 04:06 PM
ThinAir914   I'll add my vote for Castrol Super-Clean. It...   Apr 25 2005, 04:08 PM
bd1308   paint from the tin..? what paint are you referring...   Apr 25 2005, 04:12 PM
Mueller     Apr 25 2005, 04:17 PM
ThinAir914     Apr 25 2005, 04:22 PM
Aaron Cox   dont get super clean on your skin..... i do it al...   Apr 25 2005, 04:24 PM
mihai914   Castrol Super Clean is really strong stuff, if you...   Apr 25 2005, 04:29 PM
scotty b   Britt you REALLY need to find a new mechanic. This...   Apr 25 2005, 05:58 PM
bd1308   gotya...i knew very little about computers and now...   Apr 25 2005, 07:28 PM
- Lo-Fi Version Time is now: 26th April 2025 - 03:01 AM
