David Mueller |
Member ![]() ![]() Group: Members Posts: 79 Joined: 4-February 03 From: Calgary, Alberta Canada Member No.: 236 ![]() |
I've a '74 with dual webbers and the PO had put thick heat resistant gasket between the intake runner and the head. My question is do I really need it ? It's about 3/16 thick and looks like asbestos impregnated material.
The local VW guy says it's to stop the head from heating up the lower section of the intake runner and says normally they run thin intake gaskets on either side of that heat sheild gasket anyway. Any opinions ? |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
CB Performance would be where i'd start, or at a Weber/Redline distributor. they're available for 911 applications but i doubt they're the same parts.
worst-case - they can't be -too- hard to fabricate from a block of phenolic or other high-temp rigid plastic. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:47 AM |
