Oil Capacity on a Stock 2.0L, Help out a n00b |
RangerRhett |
May 1 2005, 08:41 PM
Member Group: Members Posts: 131 Joined: 25-August 04 From: Lafayette, IN Member No.: 2,620 |
Hey guys...
I have only had my teener for about 4 weeks and I am just now getting to do a complete PM overhaul... I am planning on doing the following: Oil Change Gear Lube Flush Brake Fluid Flush Air Filter (if needed) Fuel Filter (if needed) Rotors and pads (if needed) Valve Gaps Timing I have a few questions, if you all will permit me... RE: Oil Capacity Got started today and got the oil out with no problem. I also pulled the strainer to drain whatever else I could. Why is it, that when I put the plug back into the pan, and add 2 quarts of oil, the oil on the dipstick is almost 1/2" over the top mark? RE: Timing Okay, I am a young feller, and I have little to no experience on adjusting timing. I am completely confident in my abilites as a shadetree mechanic, but I need a, "Setting Timing for Dummies;" or "Distributers for Dummies;" if you know what I am saying. I have a Chilton's, a Haynes, and a Shop Manual for the 914. Unfortunately, they assume that their reader has some base knowledge of the process, of which I do not (verbiage and all). I have a timing light (craftsman), feeler gauges and the whole bit. I know the following (correct me if I am wrong)... Put car in 5th, grab one of the rear wheels (while the other is on a ramp) and turn it until you see the Top Dead Center mark on the blower (fan)...hook up your timing light to the battery and cylinder one on the distributer cap...(I think)... After that I am lost... I hope I haven't wasted members' time and space with this request. Your advice is respectfully asked and, if given, will be duly appreciated. My sincere thanks to all who respond. RR |
Cap'n Krusty |
May 1 2005, 09:46 PM
When reinstalling the screen and sump cover, NEVER tighten the nut to more than 11 ft/lbs! NEVER. Always check the oil with the car as close to level as possible. It takes a little under 4 quarts. Now, on to the gear oil..... "Flush"?? Why? Gear oil doesn't wear out, and doesn't build up a residue like motor oil, because it isn't made nasty by combustion. Save your bucks. Whatever gear oil you use, it MUST be straight GL-5. No mixtures, no "top off" oils, and NO additives! GL-4 will toast your synchros. Always remove the fill plug first, just so you know you can fill it back up after you drain it! 5.5 pints. 17mm allen key. The brake flush ............... Use a good DOT 4 brake fluid, and run at least a litre through the brake system. See my recent article on valve adjustment. Easier, better. Replace the fuel filter once a year. Use the real deal, the square one, or the round metal filter for a 1974 BMW Tii. DO NOT use a filter meant for a low pressure carb application. It doesn't remove enough cr*p from the fuel. Enjoy! The Cap'n
Lo-Fi Version | Time is now: 21st September 2024 - 10:05 PM |
