Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
Out comes the tranny. WEVO shift parts are on the way.
I can't believe how dirty it is back there from the 2000 mile WCC trip. I'll have to get in there with some soap and a brush. Attached image(s) ![]() |
Wild 6 |
See you at the next autocross. ![]() ![]() Group: Members Posts: 212 Joined: 16-November 04 From: Phoenix, AZ Member No.: 3,128 ![]() |
After installing the Wevo side shift, do not put any fore/aft preload on the casting when you mount it in the car. In other words, don’t force it to line up with the transmission mounts. Modify the transmission mounts if they don’t align with the Wevo casting. The PO (or his mechanic) preloaded mine and it eventually snapped off the mounting ears. I had to remove the Wevo casting and have the ears TIG welded back on the casting. I then modified the mounts to eliminate the preload problem.
Andy |
