Home Plating Kit, Works Pretty Good! |
Qarl |
Jun 30 2003, 08:58 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I bought a home plating kit from Caswell Plating called Copy Cad.
It's a Zinc/Cadmium Electroplating kit. It works pretty good. Next, I will dip them in yellow chromate to duplicate the factory yellow/iradescent finish on the parts. http://www.caswellplating.com Attached image(s) |
Qarl |
Jul 1 2003, 12:31 PM
Cool Harvery... you can be the resident plating expert.
I've been at it a whole 24 hours. Experimenting was fun. I did place two annodes on opposite sides of the tank. The parts were centralized vertically and horizontally between the plates. Wearing gloves, I did remove the part, reposition the part on the hanger clip. I also did this to reduce marking from the clip attached to the part. I also airated the tank to keep bubbles from depositing on the part. The setup was not "pretty" but it was effective for a first-timer. Harvey is right, the current travels through the solution along current lines, much like you would see on "magnet" diagrams. You can get areas that are in the field stronger than others. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:02 PM |
