> Wheel specs for 4 lug 15x7
grantsfo
post May 4 2005, 09:28 PM
Arrrrhhhh!
I'm thinking of getting some custom wheels (15"x7") made. What is the proper offset for 7" wheels on four lug car? I have rolled fenders in the rear. Also what is bore diameter and depth for hub centric wheels?
grantsfo
post May 5 2005, 10:35 AM
Arrrrhhhh!
QUOTE (Mueller @ May 5 2005, 07:16 AM)
QUOTE (Joe Ricard @ May 5 2005, 04:01 AM)
My thoughts exactly. if you are getting wheels made. Which from my adventure is where you will be a week from now.  Get what you want.  4 1/2" back space or 4 1/4" back space. you choose.  Price is in direct proportion to weight. the more money you spend the less wheel you get.  Track only wheels I went with the Diamond racing wheel. 15 x 8  under stock fenders. 205/50-15 Hoosiers.
by increasing the track on the front (which is 2" narrower than the rear), you can dial out some of the understeer.
the only way to do that is to use spacers, or buy rims with 2 different offsets...if you do the later, kiss rotating your tires goodbye...for some people its not a big deal....
make sure you take pictures, cause I don't believe they'll fit on the rear if they are truely stock fenders....either way, those will look cool and give tons of grip (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
I think I want to have ability to rotate tires etc if spacer solution is safe and cost effective. Although I'm used to having differnt wheels/tires on my Boxster. You just spend a little more on tires.
My rear fenders are rolled out fairly aggressively. I currently have a couple of inches of clearence with 205/50/15 Yokohama's on 5.5 wheels. Do you think I could get away with 15x8? Would offset be the same for 15x8? I know the benefits of getting wide rims on a car and would like to go as wide as possible without going the route of flares. ...at least for now.
If I go the route of spacers who sells them? Do I need to get special lug bolts?
grantsfo   Wheel specs for 4 lug 15x7   May 4 2005, 09:28 PM
Mueller   35mm offset works great in the rear, use the same ...   May 4 2005, 09:51 PM
trekkor   Funny, I was just asking the guy at the tire/wheel...   May 4 2005, 09:54 PM
Mueller   78.60mm X 15mm (let me verify the 2nd dim. tommor...   May 4 2005, 09:55 PM
grantsfo   Thanks! Appreciate your help. I havent used ...   May 4 2005, 10:18 PM
grantsfo     May 4 2005, 10:33 PM
Mueller   <...   May 4 2005, 11:38 PM
messix     May 5 2005, 12:05 AM
Joe Ricard   My thoughts exactly. if you are getting wheels mad...   May 5 2005, 05:01 AM
nebreitling     May 5 2005, 07:42 AM
URY914   When my car had stock fenders I ran 15x7's wit...   May 5 2005, 08:22 AM
Mueller     May 5 2005, 10:28 AM
grantsfo     May 5 2005, 10:35 AM
trekkor     May 5 2005, 10:55 AM
messix   wont pushing out the wheels with spacers to increa...   May 5 2005, 04:52 PM
nebreitling     May 5 2005, 06:15 PM
grantsfo     May 5 2005, 07:25 PM
Joe Ricard
  May 5 2005, 07:45 PM
Dman   Grant, are you going to Stockton on Saturday?   May 5 2005, 09:48 PM
ottox914   Joe R- Tell us more about the diamonds? How's ...   May 5 2005, 10:18 PM
Mueller   <...   May 5 2005, 10:40 PM
ottox914   My oops- thats what I get for getting all excited ...   May 6 2005, 05:54 AM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 07:06 AM
