> Home Plating Kit, Works Pretty Good!
Qarl
post Jun 30 2003, 08:58 PM
Shriveled member
I bought a home plating kit from Caswell Plating called Copy Cad.
It's a Zinc/Cadmium Electroplating kit.
It works pretty good. Next, I will dip them in yellow chromate to duplicate the factory yellow/iradescent finish on the parts.
http://www.caswellplating.com
HarveyH
post Jul 2 2003, 11:33 AM
Depending on the specific application, they may use aeration or mechanical motion of the parts to keep bubbles from adhering to the surface.
Generally, the farther the anodes are away from the part, the more even the deposition and less critical the use of shielding (current thieves) and auxiliary anodes, but the slower the rate of deposition.
Gloves are always a good idea when working with chemicals, also safety glasses and/or face shields.
Bigest problem is getting your parts absolutely clean to prevent flaws in the adhesion. A good method is to use a reverse current setup (reverse the polarity of the connections from plating, part becomes the anode) in a hot caustic bath with stainless steel cathodes. A strong solution of lye is good for this. Rinse well and follow up with a rinse in mild acid to kill any remaining caustic, rinse again, and then into the plating bath.
One of the reasons for the high cost of commercial plating is disposal of used chemicals. Lots of poisons, acids and caustics. Chromates are very dangerous, and easily detectable in the low parts-per-billion ranges. Gold and silver plating use cyanide complexes and can easily give off HCN (IMG:style_emoticons/default/hanged.gif) if you mess up.
Harvey
Qarl   Home Plating Kit   Jun 30 2003, 08:58 PM
Qarl   Headlight pivot bracket up close   Jun 30 2003, 08:59 PM
Lawrence914-6   That's pretty cool... shoot a pic when you get...   Jun 30 2003, 09:00 PM
Qarl   Lawrence... I see plating in your future... You...   Jun 30 2003, 09:02 PM
Lawrence914-6   Here's the irony in all this... By the point ...   Jun 30 2003, 09:18 PM
maf914   Karl, Great looking results. Your car is going to...   Jul 1 2003, 06:55 AM
Qarl   You can add as little or a much as you need. You ...   Jul 1 2003, 07:21 AM
914Timo   Karl, looks wonderfull !!! :boing: ...   Jul 1 2003, 07:30 AM
tod914   wow turned out real nice. what did you have to do...   Jul 1 2003, 08:24 AM
Qarl   Damni it! I should have taken pics before I p...   Jul 1 2003, 09:10 AM
Lawrence914-6   Is there an issue if the parts are touching one an...   Jul 1 2003, 09:20 AM
Qarl   The parts can touch each other, but you may get so...   Jul 1 2003, 09:40 AM
HarveyH   Technically, items touching is not a good idea. T...   Jul 1 2003, 12:24 PM
Qarl   Cool Harvery... you can be the resident plating ex...   Jul 1 2003, 12:31 PM
HarveyH   Depending on the specific application, they may us...   Jul 2 2003, 11:33 AM
Qarl   I chromate a few parts. Here is a pic. (Sorry, i...   Jul 12 2003, 05:38 PM
Red-Beard   Don't apply the plating to parts which may get...   Jul 12 2003, 06:07 PM
Qarl   I don't think this headlight pivot bracket wil...   Jul 12 2003, 06:10 PM
URY914   Karl, That stuff is so preeeeety!!! ...   Jul 12 2003, 06:15 PM
redshift   <...   Jul 12 2003, 07:42 PM
campbellcj   <...   Jul 13 2003, 09:50 AM
- Lo-Fi Version Time is now: 6th January 2025 - 04:34 PM
