RangerRhett |
Member ![]() ![]() Group: Members Posts: 131 Joined: 25-August 04 From: Lafayette, IN Member No.: 2,620 ![]() |
Okay...
Attempted to bleed the brakes because it hadn't been done in a while, according to the PO (and I havn't done it). I foolishly pumped the pedal with a nipple still slightly open (stupid, stupid, stupid) I cannot get the air out of the lines. I have a hand pump which I have been using (pump it up, stick the pump on the nipple, and then open the nipple until you start sucking). Out of desparation I opted to bleed the MC (I just cracked the lines until fluid came out). Much more fluid came out of the upper connection than the lower - by 'upper' I mean the connection nearest to the cab. Fluid didn't really dribble out of the 'lower' connection as much. I fill the reservoir to the top of the fill hole (where the cap threads on to the reservoir). Then I go to the right rear wheel, put on my pump, and then open the nipple. fluid comes out, but in dribbles and with lots of air. Then, I hear a sucking noise, and the reservoir (the fluid sitting in the threaded neck of the reservoir) has been sucked down. Do I have the wrong idea here? How can I get back on track? |
ewdysar |
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 ![]() |
Damn I've got to type faster.......
If your fluid never goes solid you may have a leak that is letting air in. Check your MC to caliper lines. Check the line(s) from the reservoir to the MC. Sounds like you're pulling in air from somewhere. And don't screw the valve too far out of the caliper, if it's loose you could pull air through the threads... |
Lo-Fi Version | Time is now: 26th June 2024 - 08:34 AM |
