Brake Bleeding, What equipment are you using?ou |
sjhowitson |
May 16 2005, 07:37 AM
Member Group: Members Posts: 478 Joined: 4-August 04 From: Moraga, CA Member No.: 2,449 |
I need to bleed the brakes on my car. I have used the old pump the brake system in the past. What new fangled equipment is out there and what works the best???? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Kargeek |
May 16 2005, 04:57 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
It's easy to do the one man pump the pedal process if you partially fill your catch bottle with brake fluid and make sure that your clear hose from your bleeder valve remains submersed in fluid. Loosen your valve, pump fresh fluid out and slowly release your brake pedal. This way you don't suck air back into the system. Been there -done it if you don't have help around. DH
Lo-Fi Version | Time is now: 25th June 2024 - 05:12 PM |
