brake light switch, only one? |
xsboost90 |
May 17 2005, 05:40 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
so i searched and looked in my haynes manual which tells me absolutly nothing and i cant find if there are more than one brake light switch or what. There is the one on the mc in the haynes manual, that one is brand new on my 19mm, but the lights arent working when i press the pedal. Does the e-brake switch need to be hooked up, i tried grounding it but still nothing.
ArtechnikA |
May 17 2005, 05:44 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
the brake light switch (there is exactly one) is a microswitch in the pedal cluster activated by the brake pedal.
( Haynes, p 129 ) the switch turns the lights off. (IOW - if it falls of or something, the lights will turn on.) but it's possible a lead could have come adrift. pull the pedal board (4mm Allen, i think...) and check out the switch. the switch(es) on the MC are only for the dual cylinder failure BRAKE warning light on the dash. |
Lo-Fi Version | Time is now: 28th September 2024 - 03:45 PM |
