Interesting SDS EFI results, Stock 1.8 vs. a 2.0 with a Scat C-25 cam |
Mark Henry |
May 16 2005, 06:44 PM
I sold the 2.0 junkyard dog (a 2.0 I made from scrap parts) it was stock except for the C-25 Scat cam and installed my bone stock 1.8
Here’s what’s happening. I haven’t even adjusted my values and I still have an OK reading on my narrow-band (Haltec AF 30) meter. I have a wide-band on the way from SDS, so I’ll have a direct comparison in about 1-1/2 weeks. My duty cycles are down about 10% across the board, I get no more than 40% (WOT) duty cycle. At highway speed I’m no more than 20% DC. I’m still using the 2.0 injectors…I think I’ll swap them out for 1.7’s and see what happens. The main interesting point is the 2.0 always lurched a bit at 1500 to 2500rpm, it was a bit of a PITA in stop and go traffic, never at normal rpms. My manifold pressure was always all over the place. I have since installed this engine in a bug with 44mm Webers and an A-1 header and it now has none of the lurching. The stock 1.8 has no lurching at all and the manifold pressure is now rock solid! Power is down from the 2.0, but that was expected. It is just as smooth as the old L-jet except for start up, as I have no cold enrichment. Cam choice is very important! When I get the 2.6 done (looks like late summer now) it will have a special MassIVe cam so we’ll see how it compares in the drivability department. Jake and I will be comparing notes to figure out the best combo’s for his and my customers. |
lapuwali |
May 17 2005, 12:17 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
This really isn't a problem with SDS specifically, but with any speed-density system. Megasquirt, Haltech, even D-Jet all fall into the same boat. Most aftermarket systems are speed-density, in fact. If you're running a wild cam, you really have to use alpha-N (TPS instead of MAP as the load sensor), which SDS will do just fine (as will most other aftermarket systems). With some systems (Link will do this, as will Electromotive), you can use both manifold pressure and TPS as load sensors, using TPS at low engine speeds where MAP tends to fluctuate unpredictably; and using MAP at higher engine speeds, where MAP tends to be fairly stable even with really hot cams. As far as I know, SDS doesn't do this, nor does MS (though there's some work in progress to change that). In practice, alpha-N alone works OK on the street, if the MAP sensor is used for barometric correction. Bosch MFI is basically an alpha-N system with baro correction. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:46 AM |
