Interesting SDS EFI results, Stock 1.8 vs. a 2.0 with a Scat C-25 cam |
Mark Henry |
May 16 2005, 06:44 PM
I sold the 2.0 junkyard dog (a 2.0 I made from scrap parts) it was stock except for the C-25 Scat cam and installed my bone stock 1.8
Here’s what’s happening. I haven’t even adjusted my values and I still have an OK reading on my narrow-band (Haltec AF 30) meter. I have a wide-band on the way from SDS, so I’ll have a direct comparison in about 1-1/2 weeks. My duty cycles are down about 10% across the board, I get no more than 40% (WOT) duty cycle. At highway speed I’m no more than 20% DC. I’m still using the 2.0 injectors…I think I’ll swap them out for 1.7’s and see what happens. The main interesting point is the 2.0 always lurched a bit at 1500 to 2500rpm, it was a bit of a PITA in stop and go traffic, never at normal rpms. My manifold pressure was always all over the place. I have since installed this engine in a bug with 44mm Webers and an A-1 header and it now has none of the lurching. The stock 1.8 has no lurching at all and the manifold pressure is now rock solid! Power is down from the 2.0, but that was expected. It is just as smooth as the old L-jet except for start up, as I have no cold enrichment. Cam choice is very important! When I get the 2.6 done (looks like late summer now) it will have a special MassIVe cam so we’ll see how it compares in the drivability department. Jake and I will be comparing notes to figure out the best combo’s for his and my customers. |
crash914 |
May 17 2005, 01:54 PM
its a mystery to me Group: Members Posts: 1,827 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Yea, purple (magenta) line is the map signal. This is with 4 throttle bodies tied into one hose with an added fuel filter to try to smooth out the signal....I was showing that I only get around 3Kpa variation with steady state cruise. This is a 2666 with a Jake special cam...so the vacuum signal is pretty wild..
If anyone wants to help me with the rpm, DC1 spike, I won't mind.. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:43 AM |
