MarkG |
Member ![]() ![]() Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 ![]() |
Well, my $831.76 alignment is done, will be picking car up this afternoon. They had to tap the tie rod ends to get enough toe. Something is not right here .....
I still think its because of the way I incorrectly placed the bump steer spacers (I lowered the cross member rather than raising the steering rack) created a distance issue from the tie rod to the A-arm/strut, but shop believes the turbo tie rods were not threaded deep enough........ Asked them to bleed my brakes as my pedal has about 3-4" travel after I added 19mm m/c and rebuilt front calipers and replaced hoses. They tell me the brake proportioning valve is bad.....they can hear it click which they say indicates it's bad. They were unable to help with the mushy pedal (I don't believe they bled the valve). Soooooo..do these go bad or should I try bleeding it before replacing it (with V.W. Tee fitting....)? |
MarkG |
Yes, and spacers were included and installed. Either there was a minor manufacuring defect (which I doubt) or my original thought (improper bump steer RACK spacer install - I lowred the cross member rather than raising the steering rack) moved the geometry enough to push out the whole steering rod assembly length just enought that the tie rod ends themselves could not be brought in enough. Shop called a few places with my hypothesis and they all felt it would not be enough of a difference to affect the adjustment capabilities......who knows. May be it was a factory tap depth issue after-all - heck the boots didn't even last 1 mile!!!! |
Lo-Fi Version | Time is now: 26th June 2024 - 12:39 AM |
