Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I sold the 2.0 junkyard dog (a 2.0 I made from scrap parts) it was stock except for the C-25 Scat cam and installed my bone stock 1.8
Here’s what’s happening. I haven’t even adjusted my values and I still have an OK reading on my narrow-band (Haltec AF 30) meter. I have a wide-band on the way from SDS, so I’ll have a direct comparison in about 1-1/2 weeks. My duty cycles are down about 10% across the board, I get no more than 40% (WOT) duty cycle. At highway speed I’m no more than 20% DC. I’m still using the 2.0 injectors…I think I’ll swap them out for 1.7’s and see what happens. The main interesting point is the 2.0 always lurched a bit at 1500 to 2500rpm, it was a bit of a PITA in stop and go traffic, never at normal rpms. My manifold pressure was always all over the place. I have since installed this engine in a bug with 44mm Webers and an A-1 header and it now has none of the lurching. The stock 1.8 has no lurching at all and the manifold pressure is now rock solid! Power is down from the 2.0, but that was expected. It is just as smooth as the old L-jet except for start up, as I have no cold enrichment. Cam choice is very important! When I get the 2.6 done (looks like late summer now) it will have a special MassIVe cam so we’ll see how it compares in the drivability department. Jake and I will be comparing notes to figure out the best combo’s for his and my customers. |
MecGen |
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 ![]() |
That depends ...what is DC1?
Sorry I am unfamiliar with the terminology (sp) The RPM spike is usually in the secondary ignition its way to fast to have actually revved that quick... Later Joe (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:59 AM |
