> AN ALTERNATIVE TO THE TUNA CAN, Or At Least What I Did
Type 4 Unleashed
post May 19 2005, 01:57 AM
CREATIVE TYPE lV ENGINEERING
Group: Retired Members
I, yanked my motor yestergay, tore it down to the case, I was doing a rering and head swap, well today, I couldn't help my self, I split the case, figured what the heck, and I remembered talk on here about tuna cans. I tried one once, didn't like it.
These baffles, help keep the oil from rushing from side to side during hard corning, they actually, direct oil to the pickup, I leave about an 1/4" space on the bottom and ends, to allow the oil level to equalize in the sump, when the motor is off to get an accurate dip shit reading.
I have no pressure lose, during hard corning(i.e. green light when you go around a corner really fast).
Just thought I'd share this, and to see what opinions are provoked.
Reiche
post May 19 2005, 11:28 AM
QUOTE (messix @ May 19 2005, 10:11 AM)
wouldnt' that extra oil in the head at high rpm be keeping the heads cool.
correct me here if i'm wrong but i thought that these engines were air and oil cooled.
The bottom end is cooled by oil, but it has to circulate a lot to do much cooling. The oil doesn't circulate in and out of the heads fast enough to do much cooling compared to the air that is passing through the fins.
Even if you have oil squirters to cool the back of the pistons, they are doing less for piston cooling than the cylinder walls are.
V6914   AN ALTERNATIVE TO THE TUNA CAN   May 19 2005, 01:57 AM
McMark   Seems like a good idea! ht...   May 19 2005, 02:18 AM
Steve Thacker   I think that is a very good idea also. ...   May 19 2005, 06:20 AM
synthesisdv   the pic..........   May 19 2005, 06:21 AM
redshift   Thanks for that! I imagined the heads would ho...   May 19 2005, 06:37 AM
rdauenhauer   Good thread! Since oiling is the lifeblood of ...   May 19 2005, 09:45 AM
redshift   Accusump... it's just expensive sense. M   May 19 2005, 09:50 AM
airsix   Whoah! That's a pretty high tide there. Th...   May 19 2005, 10:57 AM
Mueller     May 19 2005, 11:04 AM
messix   wouldnt' that extra oil in the head at high rp...   May 19 2005, 11:11 AM
synthesisdv   after about two hours of track time, I have roughl...   May 19 2005, 11:15 AM
synthesisdv     May 19 2005, 11:17 AM
Brad Roberts   Great thread http://www.914w...   May 19 2005, 11:27 AM
Reiche     May 19 2005, 11:28 AM
Jake Raby   I actually sell those pieces already waterjet cut ...   May 19 2005, 11:29 AM
lapuwali   synth, are those two head pics low and high rpm, o...   May 19 2005, 11:34 AM
rdauenhauer   I dont necessarily agree with that statement, pe...   May 19 2005, 12:16 PM
redshift   James, I see that as being a running motor, then a...   May 19 2005, 01:12 PM
Jake Raby   The sump on my 2316 Hybrid hasn't bottomed yet...   May 19 2005, 01:13 PM
synthesisdv   ...   May 19 2005, 02:22 PM
synthesisdv   <...   May 19 2005, 03:31 PM
URY914   Here's the can...   May 19 2005, 03:31 PM
URY914   Update: My line on the left v/c is connected at t...   May 19 2005, 04:27 PM
- Lo-Fi Version Time is now: 27th December 2024 - 11:16 AM
