MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
Len Hoffman has my 2.0 heads. He is repairing cracked plug bosses, converting to 12MM plugs, installing 8 new seats.
I am considering dual springs new chromoly retainers. The heads have new (expensive) sodium exhaust valves. Len doesn't recommend sodium valves with dual springs, he says change the to SS valves. So, should I keep the sodium valves & stock springs or go SS with double springs & new retainers? How much performance do double springs make? The engine is a fairly fresh 2056 with Dellorto 40's and a stockish Webcam. I have the parts to convert back to Djet but will probably drive it with the carbs for a while first. The car is a weekend fun car & not a daily driver. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
what's your anticipated rev range?
my impression has been that dual springs are good for controlling valves at high revs, and sodium valves are good for transferring heat at high loads (like a top-gear freeway cruiser). so - are you building a weekend AX screamer, or a weekend long-trip cruiser? past that - i'm unqualified to express an opinion on T-IV heads, so i'll bow out and let the real experts take over... |
Lo-Fi Version | Time is now: 26th June 2024 - 02:18 AM |
