Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Found this on the TWM throttle body website....
not only is it for the linkage, it also doubles up as a common manifold for MAP readings for fuel injection.... Attached image(s) ![]() |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Or increase the diameter of the wheel and locate the two linkage arms at the sides as opposed to the top and bottom as shown so that movement will be at near right angles or tangent to the wheel. The same problem occurs with the typical cross bar linkage and the solution or compromise is the same. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 10:20 PM |
