Wide-band preliminary results, EFI guys must read!, Narrow-band sucks!!!! |
Mark Henry |
May 20 2005, 02:43 PM
10.5 AFR!! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) That’s what I was running!
I was tuning with a Haltech AF-30 narrow band and they are “supposed” to be pretty good. Since I was running so rich before, now my gas mileage should go up and the throttle seems way crisper. I’ll post my fuel values later (before and after) once I’ve fine-tuned them a bit better. Wide band users! If you’re running an exhaust extension tube, your lambda is not getting hot enough for an accurate reading! Even if it is a heated unit…mine is. The WMS wideband has an LED that lights up when it hot enough…It took almost 10 min. at the “Y” in my Ansa exhaust (with SSI’s) before I had a green “hot enough” LED. A header would most likely heat up way faster. |
Mark Henry |
May 21 2005, 04:47 PM
My duty cycles are so low with the 2.0 injectors I'm going to try some smaller injectors....I think my buddy has some 1.7 injectors (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
What other injectors fit a stock injector holder? My wideband is now hit and miss...same issue this AM but now it's working fine. Bet it makes me look like a duffus when they test it..."Ummm.... dars nutin' wrong with it" |
Lo-Fi Version | Time is now: 24th September 2024 - 01:01 PM |
