914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Guys:
I'm trying to remove the old clutch cable in order to put in my new Terry cable and I'll be damned if I can get the pin out (this is inside the car, in the front) and I'm trying to disconnect it. The nut is backed off and the clip is pulled back, but I can't get the pin out. There isn't a whole lot of room to work, but even when/if I get something to push on the pin, it won't budge. Will it only come out one way? Is there a trick that I'm missing here? Can I get the cable replaced without removing the other cover plate and the console? Any help is appreciated!! Thanks, Andy.. |
RAR |
Member ![]() ![]() Group: Members Posts: 189 Joined: 24-January 04 From: Washington state Member No.: 1,598 ![]() |
IIRC a groove gets worn in the pin part of the clevis clip. It may look lined up to push out, but it isn't. The clevis fork must be moved back and forth to get things lined up so things will slide. You should assume you have to destroy the clip, it needs replacing anyway.
Lo-Fi Version | Time is now: 19th June 2024 - 01:43 PM |
