914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Guys:
I'm trying to remove the old clutch cable in order to put in my new Terry cable and I'll be damned if I can get the pin out (this is inside the car, in the front) and I'm trying to disconnect it. The nut is backed off and the clip is pulled back, but I can't get the pin out. There isn't a whole lot of room to work, but even when/if I get something to push on the pin, it won't budge. Will it only come out one way? Is there a trick that I'm missing here? Can I get the cable replaced without removing the other cover plate and the console? Any help is appreciated!! Thanks, Andy.. |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
You're guess is correct, the pin/clevis only comes out one way. If you have a new one, you can grab it with some needle nose pliers and pull it out. There is not much room for a punch and a hammer in there. Put the wheels under each corner so if the car does come off the stands it won't go too far.
Lo-Fi Version | Time is now: 19th June 2024 - 01:34 PM |
