Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
The cost of aftermarket throttle bodies is way up there, the bottom of scale we have the CB Performance units which are about $250 each and the rest are easily 2X that about.....
so I swung by the motorcycle salvage yard in Fremont today and picked up these beauties (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) 45mm at the butterfly....they taper down to 42.5mm at the bottom... includes a nice TPS and injectors...I doubt the injectors flow enough, but who knows, I'll find out once I get the specs.... no idea of what bike they came off of yet.....price was $125 top view: Attached image(s) ![]() |
Mueller |
QUOTE(JoeSpark) Hey Mike The size of the injector hole/mounts, is this a standard automotive size, or will it be machined to fit ?? This should work, when you get the mounting figured out. My vote is #1, the simpler the better, less things to go wrong... later Joe the seal on the end of the injectors looks very close the stock 914 injectors, however the motorcycle injectors are nice and short...I will be using them..they flow enough for 165+ horsepower so I'll be okay for now...... |
Lo-Fi Version | Time is now: 20th April 2025 - 10:52 AM |
