> Carter fuel pump, Where would you put it
michelfg
post May 27 2005, 07:10 PM
We bought this 914 a couple of years ago. It had the fuel injection taken out and replaced with a carburetor, weber dfev 32/36 so I am stuck with this setup. Recently it has had trouble starting and idling. One of the things we found that the fuel pump a Faset seemed to stop pumping when we cranked the car. Any ideas on that? So I read the internet and finde out racetep says you should use a Carter fuel pump, so I bought one. The Faset was installed under the rock guard under the fuel tank. The Carter does not fit there. Any ideas where I should put this? My car a 1972 1.7 that my son used for a daily driver until we started having problems. Thanks for the help.
Allan
post May 27 2005, 09:06 PM
Teenerless Weenie
QUOTE (SLITS @ May 27 2005, 08:02 PM)
Fuel level is higher than where you would mount the pump under the engine shelf on the firewall. Shouldn't be a problem. Just cut one of the hoses and see what happens (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
There should be plenty of room up front to mount it.
And yes, electric pumps are better "pushers" than "suckers".
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) Ilove this guy.....
- Lo-Fi Version Time is now: 6th January 2025 - 08:36 PM
