Part Pricer |
Believe everything I post ![]() ![]() ![]() Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 ![]() ![]() |
About three weeks ago, I installed a brand-new Bursch exhaust on my 914. At that time, I decided that I was going to install it as I had received it, then remove it later to treat it with some good, quality very high temperature (VHT) paint.
Today, I pulled the exhaust off and this is what I found. The original paint had flaked everywhere. It was extremely easy to brush off the paint with a rag. I took these pictures right after I removed the exhaust. After I took these pictures, I put a metal finishing pad in my detail sander and got almost all of the original paint off very easily. It is now sitting outside with a new coat of PJ1 Fast Black waiting to be reinstalled. Attached image(s) ![]() |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
QUOTE Can you use a bus-type extractor Seems like you should be able to. On my turbo I used an extractor that came off a bus motor with stock HE's. It bolted directly to my 1.8 SS 914 HE's without any problem. So the spacing must be the same in some applications. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:18 AM |
