Just ordered an Accusump.... |
Joe Bob |
Jul 13 2003, 09:53 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
The T-4 motor in my 356 has decent head temps
but the oil temp gets high after about 20 minutes. I am running a stock oil cooler and electric fans w/o a crank run fan....custom sheet metal due to a T-4 never being designed for a 356 tail dragger. So.....I ordered a sandwich plate, diverter, Mocal oil cooler, a $hitpot of braided lines, and an Accusump. For those not familiar with an Accusump, it is a 3 quart capacity pre oiler system. You hit a switch prior to engine ignition and it pressurizes the oil system up to optimum operating parameters. THEN you fire the motor up. It adds three extra quarts of oil, allows the engine to start with full oil pressure and helps with extra cooling. It also has a check valve that pressurizes ONLY the engine side. Then the thermostat opens at temp and allows warm oil to the cooler...... |
seanery |
Jul 13 2003, 02:14 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Is that similar to the Morosso Accumulator?
(IMG:http://www.9xauto.com/images/morosooil.jpg) Some Facts The Moroso Accumulator is an engine saving add-on to any high performance oiling system. It is designed to provide oil pressure should the normal engine oil pressure drop below the optimum operating level during hard acceleration, severe cornering or hard braking or when oil surges away from the oil pump pickup. Capacity is 1.5 qrt., and is a vertical, gravity fed unit designed for small-displacement light-duty applications and includes mounting brackets. Oil pressure keeper (Add to Cart) $80.00 |
Lo-Fi Version | Time is now: 20th June 2024 - 05:49 AM |
