> Tranny Woes, any ideas for prolonging?
Bezerker420
post Jun 8 2005, 12:28 AM
just bought a wonderful '72 914 [tailshifter] the earlier less desired one right?
tranny is loose.....shifting is sloppy....
1st is a bitch to get into unless rolling, 2nd barks unless you ease it in, almost double-clutching is neccessary......4th likes to fall back into 2nd unless i slap the stick to the right before shifting..... any of these sound typical? or are tranny woes more uer specefic...?
any ideas on prolonging this box till i get the $$$ for my massIVe motor/tranny combo? this car is my daily driver......i can take it easy on her and ride it out tho....
[I think]
xsboost90
post Jun 8 2005, 05:51 AM
i just sorted all of my shift bushings out, and now i can find gear,but i still have to ease it into second, and creeeep it into first. IM thinking my clutch is dragging slightly, and my synchros are probly toast. Make sure your clutch is adjusted correctly and not too loose/tight. Mine was too tight- no play in first inch or so and tight all the way to the floor- and it was making it real hard to shift. Loosened it abit and its much easier. Now if i can figure out my idle problems itll be golden.
Bezerker420   Tranny Woes   Jun 8 2005, 12:28 AM
redshift   Typically unattended. Get the shifter bushings so...   Jun 8 2005, 12:31 AM
Dr Evil   I agree. First you must replace all of the bushing...   Jun 8 2005, 12:54 AM
McMark   Replace them even if they look fine. All of them....   Jun 8 2005, 01:37 AM
Red-Beard   shifter adjustments: http://home.san.rr.com/pb914...   Jun 8 2005, 04:12 AM
xsboost90   i just sorted all of my shift bushings out, and no...   Jun 8 2005, 05:51 AM
Red-Beard   How about reverse? The typical symptom for draggin...   Jun 8 2005, 06:05 AM
Red-Beard   Open up my tranny article and read the last couple...   Jun 8 2005, 06:09 AM
Bezerker420   wow, im totoally stoked on the amont of feedback s...   Jun 9 2005, 02:15 AM
Rhodes71/914   ...   Jun 9 2005, 01:17 PM
Red-Beard   You need: Entire Shift linkage Shift Selector (Th...   Jun 9 2005, 05:40 PM
Dr Evil   I have a bar and an side shift cover
- Lo-Fi Version Time is now: 6th January 2025 - 04:15 PM
