DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
The next incarnation of MegaSquirt, ULTRAMEGASQUIRT is going to have onboard DIS and a driver for the Bosch LS4u wideband 02 sensor. The whole package on 1 board. I can hardly wait. Imagine no more worrying about a dirty dizzy, springs, putting oil on the felt, vacuum advance. Time it once and forget about it (course that one time is gonna be b***h). Run better gas and a hotter chip for the track with a little more advance.
The whole system will use real automotive connectors, no more DB 37 pin connectors. Sounds like the little kid on the block is growing up. Anyone have a crank trigger on their 4? The only spot I can see for one is replacing the spacing washer behind the fan with a machined trigger wheel. It appears that you could mount the sensor off the studs that attach the oil cooler This is gonna be one long winter. I got a s**tload of things to do. Dave |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Dave,
Ever think of using the flywheel to trigger the sensor(s)? Any compentent machine shop can index it for you. Some Motronic systems (like on the 3.6 911 motors) use the flywheel. |
Lo-Fi Version | Time is now: 30th June 2024 - 08:57 AM |
