Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
What is your favorite combo.
I need to stay in the 4500-6500rpm powerband. I can tach out at 7-7300rpm on the limiter. I have a spare trans I can build up now and then install... whenever. KT |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Rich - you cannot just make a statement that a set of gears as an X rpm drop between shifts. It is dependent on RPM.
For instance, on a stock /4 box, the difference between gear ratios between 2nd and 3rd is 1.498. So if you shift from 2nd to 3rd at 3000rpm, it will be a drop of 1000 rpm. If you shift from 2nd to 3rd at 7000 rpm, it will be a drop of 2300 rpm. Demick |
Lo-Fi Version | Time is now: 20th June 2024 - 05:54 AM |
