Subaru WRX Powered 914 |
WRX914 |
Jun 10 2005, 05:10 PM
2.5 WRX STI hybrid powered beast Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region |
Well, the car is finally on the road. The motor mount that we fabricated is a nice unit. I looked at all of the others, and I did not find anything that made me feel comfortable to use. Our is a full cradle, we relocated the turbo and intercooler. Fabricated our own exhaust (ceramic coated), re-engineered the factory wiring harness and it truely kicks some major bootie. We ran a 2005 997 carrera and shamed him...bad. He could not believe it. We are finishing up the details on this kit and they will be offering it soon. Be sure to look for us at the German Auto fest. We will be there with bells on! Look for the two 914s that have "Porsche Turbo" above the rockers. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif)
Lets hear what you have to say!!! |
plymouth37 |
Jun 16 2005, 01:25 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
Just a little more info on the kit. the renegade hybrids kit available next month will make it possible to install any EJ series subaru engine into a 914,the number behind the EJ designates engine(EJ22 = 2.2 liter). these include:
EJ18: Found in Imprezas from 1993-1997. Rated at 110hp and 120 ft-lbs EJ22 Phase I: Found in Legacies from 1990-1998 and Imprezas from 1995-1998. Comes rated at 130hp and 137 ft-lbs, 135hp and 140 ft-lbs, or 137hp and 145 ft-lbs. EJ22 Phase II: Found in Legacies in 1999 and Imprezas from 1999-2001. Rated at 142hp and 149 ft-lbs. EJ22-T Phase I: Found in Sport Sedan and Touring Wagons (Legacies) from 1990-1994. Turbocharged and non-intercooled. Rated at 160hp and 181 ft-lbs. Closed deck, cast pistons, forged rods, oil squirters: turbo motor. Poor flowing heads. EJ25 DOHC Phase I: Found in Legacies from 1996-1999, Imprezas in 1998, and Foresters in 1998. Rated at either 155hp and 140 ft-lbs in 1996 or 165hp and 162 ft-lbs in 1997-1999. EJ25 SOHC Phase II: Found in Legacies from 2000+, Imprezas from 1999+, and Foresters from 1999+. Rated at 165hp and 166 ft-lbs. There was a slight compression ratio change from 1999-2000 where it went from 9.7:1 to 10.0:1. USDM EJ20: US Domestic Market WRX. Found in 2002+ WRXs. Rated at 227hp and 217 ft-lbs. Turbocharged, intercooled, open deck, and decent heads. EJ25T DOHC: Available in 2004 in the Forester XT. Rated at 210hp and 235 ft-lbs. Turbocharged, intercooled, VVTi (Variable Valve Timing), and drive by wire. EJ25T-STi DOHC: Available in 2004 in the WRX STi. Rated at 300hp and 300 ft-lbs. Turbocharged, intercooled, AVCS (Active Valve Control System), drive by wire, intercooler sprayer, and semi-closed design |
