william harris |
914 Restorer ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 ![]() |
OK, exhausted myself (of course working under jack stands is never fun) last night trying to reinstall the master cylinder so I could hook up Eric Shea's beautiful (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) pedal assembly (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) As anyone who has done this knows, the plastic lines up to the reservoir connect to about a three inch long brass line that fits into two press fit rubber boots on top of the master cylinder. Well you can't press them in after the cylinder is attached to the bolts coming thru from the pedal assembly. So what I have tried and tried to do is to pull the lines down about an inch or so, push them in and then have my son gently pull the lines up from the top while I push the master cylinder onto the bolts and into position. It just ain't working. Either the plastic lines kink (not good) or the damn things pull out of the master cylinder before I can get it into place. After trying this approach for about an hour I decided it was time to go watch TV. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) Any suggestions for a better method? Oh, the damn grommets want to come out of the lower panel when you push the lines, making for more mischief. I gotta remind myself I do this for fun and enjoyment. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
mikelsr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region ![]() |
If I can remember correctly here is what I did (after lots of hit and miss).
1) Pulled down on the lines (loosened the reservoir tank) to get a bit of slack in the lines. And yes the grommet came out. 2) Attach the rubber boots to the lines next. 3) Put the mc on to the bolts (at the ver end), then using finger power pushed the boots (with lines attached) into the mc. This took a lot of effort on my part. If I were to do it again I think I would put ky gel on them (the gel shouldn't hurt the boots and it will evaporate - don't use vasoline (sp? ) it is a petroleum product). 3a) Put the grommet back in place. You might want to lube the lines when pulling them back up. 4) Push the mc all the way back onto the bolts and tightened everything up. Make sure that you have the push rod centered in the mc before you push the mc back. 5) Adjust the brake pedal 6) Adjust the brake light switch I have pictures of the brake light switch. I don't know how to post an exact link to the response but it is on page 17, the 9th entry. Light switch Good luck, Mike |
Lo-Fi Version | Time is now: 18th June 2024 - 05:13 AM |
