Tips to reinstall master cylinder?, Plastic lines - come out or kink!! |
william harris |
Jun 18 2005, 09:43 AM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
OK, exhausted myself (of course working under jack stands is never fun) last night trying to reinstall the master cylinder so I could hook up Eric Shea's beautiful (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) pedal assembly (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) As anyone who has done this knows, the plastic lines up to the reservoir connect to about a three inch long brass line that fits into two press fit rubber boots on top of the master cylinder. Well you can't press them in after the cylinder is attached to the bolts coming thru from the pedal assembly. So what I have tried and tried to do is to pull the lines down about an inch or so, push them in and then have my son gently pull the lines up from the top while I push the master cylinder onto the bolts and into position. It just ain't working. Either the plastic lines kink (not good) or the damn things pull out of the master cylinder before I can get it into place. After trying this approach for about an hour I decided it was time to go watch TV. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) Any suggestions for a better method? Oh, the damn grommets want to come out of the lower panel when you push the lines, making for more mischief. I gotta remind myself I do this for fun and enjoyment. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
firstknight13 |
Jun 18 2005, 08:43 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) ok here is how YOU do it !!!very simple now but it took me a couple of hours to figure it out...... install the master cylinder in then take strong mason string and loop it around the plastic line 3-4 inches up. have two lines dangling down. wrap your fingers around the string and pull down straight and hard and your done!!! oh!! lube the ends first.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Lo-Fi Version | Time is now: 18th June 2024 - 05:24 AM |
