SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
sooooo, if i were to sell my car (not saying i am going to)(yet) ...
what do you think i could get for it? assuming i get it all cleaned up (paint buffed out again) and get all the goodies installed (rollerbearings, new wheels & tires, new shocks etc.) ... for those of you who don't know the car, i went through a pretty extensive restauration 3 years ago, spend well over $20k on the car so far. you can read about it here, click on the url then on the "Pictures" link ... http://www.sirandy.com/projects/cars/ here is what you would get: - 1970 914-4 - extensive restauration done 3 years ago, all rust taken car off (wasn't much to begin with), replaced rear clip, new seals, new main wire harness - warmed over 2056 (Bad Boyâ„¢), 96mm KB Pistons, dual webers 44 IDF, MSD ign. + dizzy, EuroRace "H" Cam, 9:1 Compression, Tuna Can Oil Sump, 911 rockers, and tons of other goodies. FAST ... - 916 Bodykit, flares and bumpers and spoiler and flared rockers all molded in - SSI Stainless Steel Heat Exchangers, MANTA Performance Muffler (car got HEAT) - sideshifter 901 transmission, Sachs Racing Clutch, light flywheel - fresh paint, Guards Red (911 color, L 80 K) - full rollcage by "TC-Designfab", PCA, POC, PRC, SCCA legal - 911 Style Carbon-Fiber Dash from "Getty", 911 gauge cluster - Street wheels & tires: 8" x 16 Ronal Alloy with 225/50 x 16 front, 9" x 16 Ronal Alloy with 245/45 x 16 rear - Trackwheels & tires: 7x15 "Cookie Cutter" with GoodYear R250 23.0x9x15 Racing Slicks all around - RennShift performance shifter - custom chrome shift knob - center console - high torque starter - GT style engile lid - brand new factory relay board - clutch tube reinforcement - 350mm momo prototypo steering wheel - moveable pass. seat - brand new carpet, new dash and doorpanel vinyl front suspension: - Complete 911 Carrera ('86) front Suspension with Steel Cross-Member - turbo tie rods - bump steer kit - 22mm Tarett Sway-Bar - 19mm Master Brake Cylinder (911) - Vented and cross-drilled 911 Carrera Rotors, Carrera Calipers (freshly rebuild), new brake pads - Boge shocks - 70mm wheel studs with various spacers rear suspension: - new trailing arms (powdercoated yellow) with mueller rollerbearings and new wheel bearings - 914-6 Stub Axles with 911 Hubs - 100mm wheel studs with various spacers - Vented and cross-drilled 911 Carrera Rotors, Carrera Calipers (freshly rebuild), new brake pads - Adjustable Bilstein Shocks with 180lbs progressive Springs - 911 style handbrake setup everything works, all mechanicals, all electrical i think that's it. oh yeah, i also won the "Best Custom" award at the WCC '04 show & shine (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) so, what'ch'ya'all think? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy some pics: (IMG:http://www.914world.com/pix/mycar/02.jpg) (IMG:http://www.914world.com/pix/mycar/03.jpg) (IMG:http://www.914world.com/pix/mycar/04.jpg) (IMG:http://www.914world.com/pix/mycar/05.jpg) (IMG:http://www.914world.com/pix/mycar/01.jpg) (IMG:http://www.914world.com/pix/mycar/06.jpg) |
vortrex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None ![]() |
well...if you said the $50k pro resto with raby motor car was not worth $15k, I would say your car is probably worth $7-8k.
Lo-Fi Version | Time is now: 24th June 2024 - 05:42 AM |
