Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I have been brain storming again and think that I may have found a feasable MFI pump for our beloved TIV 4cyl.
Any interest? |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
I didn't know Wes could make new cams...Hmm. No reason you couldn't do MFI with a V8. Alfa did with the Montreal. Two 4-cylinder pumps end to end, with only one logic section. MFI, electronic or no, would be more expensive than an EFI system (and you don't really have to rebuild anything regularly on the EFI), but it has a number of inherent advantages. EFI has a really hard time doing sequential at anything over a 40% load or thereabouts, unless you use multiple injectors per cylinder and stage them. Vaporization is better with MFI just from the higher pressures involved. Since all gas MFI systems have just been modified diesel systems, and diesel is nearly always direct injection into the cylinder, you can make MFI into gasoline direct injection relatively easily. This brings a number of advantages in operating at the edges of the envelope, and can bring big gains in emissions while retaining wild valve timing. |
Lo-Fi Version | Time is now: 27th June 2024 - 01:35 AM |
