Alameda a/x in car video, hi-res and lo-res |
Trekkor |
Jun 22 2005, 06:43 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Attached image(s) |
jhadler |
Jun 23 2005, 11:26 AM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
trekkor,
Nice video. Get a wide angle attachment for the camera, and you'll be able to see alot more. Well worth it. Oh, what is your brake set up? You need to get better brake modulation, or all that flatspotting is gonna bust your budget. If you're running race pads, DON'T. Not for an autox. If you're running a 19mm master, consider the 17mm. Contrary to popular belief, the 19mm doesn't give you better braking power, it just makes the pedal feel firmer. The 19mm will require less travel but more pedal pressure. Some people like the feel of the 19mm, some people can better modulate the brakes with the 17mm. That's often just an issue of preference. But the brake pads make a big difference. Lot's of other things that you can look at. But those flatspots can get really expensive. BTDT. -Josh2 (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:02 AM |
