> Suspension adjustments?, What the!!!!
Gearren
post Jun 29 2005, 05:12 PM
I just finished replacing all the suspension bushings, ball joints, installed Bilstein shocks, 140 lb springs and turbo tie rods...What a job! I'm getting it ready to take it to the alignment shop. I have 2 questions/concerns.
If I set the front axle ride height at the Haynes spec, it seems like the body of the car is way up off the wheels, higher than the rear ride height. I elected to set it at 6 3/4" at the center of the torsion bar cap, which gives me a 3/8 difference between the front and rear ride heights. Is this OK? Am I missing some sophisticated geometry concern by setting the front height this way?
Second question involves the right vs left rear height. I set both struts the same, with the height clip in the fourth ring from the bottom, but the right rear sits 1/4" lower than the right. In order to correct this left/right imbalance, should I set one strut clip higher or lower than the other? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
nebreitling
post Jun 29 2005, 07:59 PM
Member Emeritus
unless you have a trailer, be sure to give it a 'rough' alignment just to get it to the shop. or spend a few hours doing your own 'home' alignment, it's surprisingly easy.
take that page of the haynes and rip it out. lower the sucker. just make sure that your A-arms/tie-rods are no lower than parallel to the ground, else you are going to have some gnarly bump-steer. but you should definitely set the car up with a bit of rake, ie the front slightly lower then the back.
that's a little odd. make sure that the front end is even right-to-left. raising one corner affects the other three, so getting the car level can be a bit of trial and error. also check to see that your springs are seated correctly. but i wouldn't set the shock clips differently (unless i was running oval race tracks, lol)
Gearren   Suspension adjustments?   Jun 29 2005, 05:12 PM
nebreitling     Jun 29 2005, 07:59 PMGearren   Thanks for the info! Been crawling under and ...   Jun 30 2005, 02:26 AM
Joe Ricard   Personally I have mt car set at 4" @ all front don...   Jun 30 2005, 05:02 AM
rhodyguy   to equalize the dif in in the rear, side to side, ...   Jun 30 2005, 10:07 AM
- Lo-Fi Version Time is now: 6th January 2025 - 06:16 PM
